Ok then I'm new. So?Like I said, new.
Is the resolution of that map the same as placing a pin on the port via pax app?
That's a good question. I'll try placing a pin there the next time I see a surge.Is the resolution of that map the same as placing a pin on the port via pax app?
So ... There apparently is no "set rate" for airports, they are not "protected," and surges DO occur, at least at some airports. There was a surge at PIE this morning and I dropped a pin there and it still showed as a surge.Is the resolution of that map the same as placing a pin on the port via pax app?
