I knew it was probably worthless. Thank you.During those timeframes you earn 1.1x normal time and mileage rate. Extra 10 cents on a dollar. Don’t spend it all in one place.
It’s mostly worthless. I’ve seen as much as 2.5x in my area which is more acceptable but 1.1x is a joke.I knew it was probably worthless. Thank you.
I don’t think I like your positive attitude 😝1.1 is better than 1.0.
It’s a buck more on a $10 delivery. Would you rather have $10 or $11?
It’s not positive. It’s a “better than…” attitude.I don’t think I like your positive attitude 😝
I don’t take $2 pings, so it’s never a $0.20 for me. (Nor is it 1.1 though; usually it starts with 1.2.)
And how about when it’s 1.5-1.7-2.4? I’ll take it!
Better than “3 deliveries in 2 hours for $5”. Eff those.
Not really. Boost only applies to the base fare, not to any supplements. As far as I know, there is no such thing as an Uber EATS delivery with a $10 base fare. Base fare generally ranges from $1 to $3. Any EATS delivery that pays $10 (from Uber, not the tip) generally has a pretty hefty trip supplement attached to it. In those cases, the boost doesn't matter because Uber's algorithm has an amount that it wants to offer to try to get the order delivered. If there is a boost, then the trip supplement just gets reduced by the boost amount to achieve the number that the algorithm wants. Boost only makes a difference on deliveries with no trip supplement.It’s a buck more on a $10 delivery. Would you rather have $10 or $11?
"3 deliveries in 2 hours for $5" is better than a 1.1x boost. "3 deliveries in 2 hours for $5" is $1.67 extra per delivery. You would be hard pressed to find a delivery with a 1.1x boost where the boost added $1.67 to the delivery. For a boost to be better than "3 deliveries in 2 hours for $5", the boost needs to be roughly 2x or higher.Better than “3 deliveries in 2 hours for $5”. Eff those.
Party pooper. You’re right, of course. 😂Not really. Boost only applies to the base fare, not to any supplements. As far as I know, there is no such thing as an Uber EATS delivery with a $10 base fare. Base fare generally ranges from $1 to $3. Any EATS delivery that pays $10 (from Uber, not the tip) generally has a pretty hefty trip supplement attached to it. In those cases, the boost doesn't matter because Uber's algorithm has an amount that it wants to offer to try to get the order delivered. If there is a boost, then the trip supplement just gets reduced by the boost amount to achieve the number that the algorithm wants. Boost only makes a difference on deliveries with no trip supplement.
