Vantrue N2 Pro - 128gb card ???
1 reading
16K views 63 replies 30 participants last post by  Starman@uber
#1 ·
Hi all. Can the Vantrue N2 pro use a 128gb card or is 64gb the limit?
#8 ·
im using a samsung evo 128gb (orange card)
for a month now. so far so good.
format in camera and not on the computer
format every week or two
You can format on the computer you just have to do it FAT32 but you will need to use a program to format rather than whats available with the computer.
#9 ·
#16 ·
You should use this Guiformat tool to format it as FAT32 by your Windows computer!
The note that is on page 5 of the N2 Pro manual that says to format a 64GB card on a computer, however this is from before the current firmware version.
I had already contacted Vantrue's support to verify, and they said there's no longer a need to format on a computer with the current firmware version, and that the dashcam itself allows you to format on its own. I do have the current version, and it's been formatting my 128GB cards with no issues. Just now I also formatted a 64GB card in the dashcam to test, also no issues.
Current firmware version (as of today) for the N2 Pro is here http://www.vantrue.net/Support/detail/id/68.html, and its manual is here http://www.vantrue.net/Support/detail/id/35.html.
Page 18 covers the update, but it doesn't really detail much. The process is easy: download the firmware file A95LYD.bin (latest as of today) from link above, and copy the file to the top folder (root directory) of the SD card. Put the card back in the dashcam and turn it on, it should see the file and update on its own (screen stays blank longer than usual). Once the update is done, go into the menus, then into SYSTEM SETUP, then into SYSTEM INFO, and verify it shows as version VTN2Pro8C.V10 like below. Finally, delete the firmware file from the card so the dashcam won't keep detecting it (or format the card if you don't need its contents).
#17 ·
Thanks KD!
I just got done setting up my N2 with a 256 GB card. Went smooth as butter on a hot day.
Formatted on Windows 10 before using this; https://www.disk-partition.com/free-partition-manager.html Not sure I even had to after reading your post but works/worked fine so all good.
HeHe, it's Friday. I might offer to send drunks their vids so they see how "cool" they are. LoL. (I hate drunks and are one)
#28 ·
As others have said, 256GB is supported as of the .V21 firmware.
Just an FYI, the .V29 firmware was released today. No capacity increase beyond 256GB, but other changes..
Vantrue N2 Pro Dash Cam Firmware Update
  • Release time: 2019-05-14 14:47:23
  • Version: VTN2Pro9E.V29
  • File size: 2.99 MB
  • Update notes:
    1. Fixed the bug in battery level display.
    2. The exposure for rear camera can be set in this version.
    3. Optimized image quality, adjusted the hue issue.
    4. When the LED screen is auto off, press P button, the LED screen will be on and the video will be saved at the same time.
#29 ·
I'll check out the update in a week or so, I try to avoid updating immediately.
I see my suggestion of adding an indicator for the sd card capacity was not added. I'll have to email them again. Basically I want a bar showing how full the sd card is so I know when to swap it out before files get deleted.
I would appreciate everyone reading this post to go to the link and put in a request. The more that request it the better chance it gets added to the camera, even if you don't want it please put in a request, you never know when you will change your mind about it.
#33 ·
128g will give you about 10 hours of recording if you use both cameras....inside and out.
That's pretty much what I figured it to be, the packaging said 640 minutes video, I don't drive that long, so 1 is perfect. I wish I had gotten the Vantrue earlier, instead I went with a cheaper brand to start with and that piece broke in a month. They still have the stupid thing to fix it. Got the Vantrue a month ago because I got sick of waiting on the repair. If I get it back, I'll ebay the thing lol.
#34 ·
  • Update notes:
I'll try updating mine again but I think the internal battery is bust on mine. It used to keep resetting to 01/01/2017 and thusly overwriting itself since videos recorded on 01/01/2017 are the "oldest" videos on the damn thing... I finally updated it to the prior most recent update and all it did was change it so it resets to 01/01/2018 now... ?
#42 ·
Depending on your vehicle type, stick it somewhere in the back to record "traffic issues" behind you.
I did that on the recommendation of a Beverly Hills pax that turned out to be a personal injury lawyer.
I have mounted my old one direction camera in the rear window facing backwards. I don't save the footage from that one like I do from my main camera, however if something happens I'll have it.
#43 ·
I was reading some other thread where someone is using two N2 Pros, both mounted up front on the left and right. Seems like that would take care of the blind spots available to the riders when just using one cam, and also increase coverage angle of the outside view.
I would suggest using a high endurance card when recording constantly, unfortunately they max out at 128GB currently.
#44 ·
Honestly, the thing is garbage. I had to reset it every couple of days. The reason it's sent off for repair is because it stopped resetting. Got stuck on the warning/load screen
#45 ·
  • Update notes:
  • Release time: 2019-05-27 15:51:34
  • Version: VTN2Pro9E.V30
  • Update notes:
    5. Fixed the distance bug in parking mode, the normal distance should be 4-5M.
Looks like they fixed a bug from the previous firmware.
