Under driver can’t afford to replace the tires
325 views 14 replies 13 participants last post by  Haanjo
#1 ·
Very dangerous!
#4 ·
And here we were led to believe you can make good money in Boston. 😆
"With Massachusetts’ 2025 pay floor of $33.48 per engaged hour and 50 % deadhead miles, a driver’s net earnings are roughly $8–12 per total clock hour before any income tax—after costs and that figure does not include tips." -ChatGPT
The minimum wage in MA is currently $15 an hour. 😆
Am I making any sense yet?
#6 · (Edited)
When I was traveling through Ohio and doing a food delivery pickup at a Chipotle in Athens, I backed into a parking spot, leaving my front tires cocked to the left. When I returned to my car, I noticed that the inside of my left front tire was worn down to the steel belt!
Because I didn't have enough money to cover gas, camping, food, beer, and a new tire, I just kept working, though I turned off Lyft so I wouldn't get anyone else hurt in the event of a blowout, which I was mentally prepared for at any time.
Drove about 100 more miles that night doing food delivery, and the next day found a used tire 20 miles away for $30, installed. When the repair guy saw how warn my tire tread was on the inside, he said,
"You's lucky!".
Personally, I think it was more than luck! If I hadn't parked the way I had to pick up that Chipotle order, I'd never notice my tire tread was so low, because I couldn't see it when I parked normally, without my wheels cocked. God works in mysterious ways! 🙏
#7 ·
Those tire manufacturers said a set of new tires will last 70-80k miles. In reality, it is about 40-45k (down to a few cm of tread).
Every 1.5-2 year, you have to change tires. Brakes are the same. It is one of those things that you have to change almost every 2 year.
EV cars are better than gas cars because there's less maintenance.
