But rematch doesn't apply to taxis and they were included in the signage. Either way, I guess I'll ignore the signage and continue to use departures as normal.Yes. It means you must enter the garage from arrivals-as it has always been.
This sign is to alleviate confusion from the new rematch entry point which is accessed via departures.
Maybe a large amount of drivers during rush hours are trying to avoid the backup into arrivals and using the rematch entry point instead?
This is the Port reminding us where to go.
Tickets will likely come later if no one heeds their first warnings.
Weird. I have never seen that before.But rematch doesn't apply to taxis and they were included in the signage. Either way, I guess I'll ignore the signage and continue to use departures as normal.
That's the whole idea.That sign would lead you to think you should be dropping your PAX @ Arrivals and not Departures...Wonder how many drivers, dropped a bunch of PAX with a ton of luggage @ Arrivals....
I thought the idea was you "can" drop at arrivals, OR departures. I can't read it very well, but it looks like that sign says Uber/Lyft/Taxis Must Use The Arrivals drive.That's the whole idea.
Dex - thanks for the info, does this mean you MUST use arrivals or you MAY use arrivals? Sorry if this question sounds stupid, just want to make sure I get it right.During peak drop-off times only (i.e. 5a-7a), and when that message is posted... you are ok to drop at Arrivals.
That's what I'm wondering....I'll play it by how busy it is. I do XL, and I'm not going to force a family of 3 with big ass suitcases and carryons to go to arrivals and haul all that shit up the escalators. I usually ask, if departures is busy and PAX has no luggage if they want to go to arrivals, anyway.Dex - thanks for the info, does this mean you MUST use arrivals or you MAY use arrivals? Sorry if this question sounds stupid, just want to make sure I get it right.
