1 - 4 of 4 Posts
Cool
Looks Sturdy too.
Welded aluminum frame.
Well thought out creation.
After requests & suggestions from a few thousand users, i am sure it will evolve.
If the tires & seat were detachable ( seat foldable)
It could transport in 1/3 the space.
$4700 is too much for this device. With that price, it would be better it comes with solid tires and non spoke alloy trims for users.
OR MAYBE A THICK WALL. P.V.C. TUBING FOR THE FRAME.
WHEN I WORKED AT JOHN DEERE, WE CALLED THE SQUARE IRON EQUIPMENT FRAME STOCK " TUBING"
PV.C. IS WELDABLE THERMALLY.
( I HAVE WELDED THICK WALL P.V.C. DRAINAGE PIPES IN PLANTS UP TO 4' DIAMETER)
WEATHER & CORROSION PROOF & LIGHTWEIGHT.
P.V.C. IN COLORS COULD ELEMINATE WEIGHT, PAINTING, AND ALUMINUM WELDING.
ALL BRINGING COSTS DOWN.
Look at the Number of WELDS & THE CONSTRUCTION OF THIS THING !
This Frame would survive Motorcross for 10-20 years !
$4,500.00 is Cheap for the amount of work put into this.
Better built than my pickup truck .
Nobody builds anything this well anymore.
( I WOULD CONSIDER A BELT DRIVE TO REDUCE WEAR, NOISE & MAINTENANCE. CHAINS STRETCH & RUST)
THE WAY THIS RIG IS SET UP, YOU COULD INSTALL MOUNTAIN BIKE 21 SPEED GEARS & REALLY MOVE ON 50% OF THE BATTERY DRAW OF 1 GEAR.
HE ENGINEERED OFF OF ELECTRIC BICYCLES.
SO, THE DRIVETRAIN IS MUCH WEAKER THAN THE FRAME.
1 - 4 of 4 Posts
