1 - 4 of 4 Posts
Technological question: Can I accept and start a trip on one device and, sometime during the course of that run, switch to another device to continue the trip without losing continuity? Thanks.
You cannot.
Example: Device #1 needs to be restarted or the app is having issues. If you restart the device or attempt to kill the app, the trip is still active and you are still technically logged in. If you try to login with another device, it says you are connected with another device.
Only way to to connect to another device is to go offline and then connect with the other device. There are times when I am at home and login with my phone as I just keep my tablet mounted in car. I get a ride, which it would be ideal to jump in the car and let the tablet take over. Unfortunately, I am stuck on my phone until the ride ends. At that point I can switch over.
Actually, the new update seems to allow you to use two phones. After I updated it, I was able to start a trip with my Samsung and end with my Nexus. But I also noticed you can't switch between a droid and an iPhone.
1 - 4 of 4 Posts
