1 - 3 of 3 Posts
Question for Select drivers and above
Do you stay online with Select , XL only?
If so , how does it work out for you?
Select tips seem to be few and far beween but I usually keep x and select on , how about you,
Too many select cars now. You won't make a decent amount in a reasonable time if you keep only those two on.
Go to passenger app and check the Sel ride and do a "Set location by pin" then pan around Toronto map, you'll see countless select cars. Sel requests are about 4% of the whole uber market.
I really think uber should lower the select prices a little so they they are more common.
I'm fine with $1.50/km. If it'll bring more pings.
Discussion Starter · #3 ·
Valid point , great idea
1 - 3 of 3 Posts
