...think I will make it? 😁
Likely because I was already Diamond.You can do two 3 point trips per day and easily make the $350…
If I’m not mistaken, some of us here were offered way more than $350 😉
Moved the goal posts on you he did.Hold it!
Why is it you only need one thousand points but I need one thousand-two hundred points?
Meh, I am at 350 points, so ya know I was never doing it!Moved the goal posts on you he did.
Dara altered the terms of the deal.
Pray he doesn't alter it any further. 😁
Yep +85% -4%Is there an acceptance rating requirement for Diamond?
If so there's no point in trying even if you get all the points.
It aint possible then.Yep +85% -4%
Hold it!
Do you have upfront pricing yet? Once they introduced that here, they lowered our requirements. Our acceptance rate only has to be 70% now😂Yep +85% -4%
Who gives a **** , you probable lost at least $600 to achieve it
Yes. I have 267 to go. I will have between 10-15 rides x day. If shirt I considered Uber eats. I am in the DMV .
I am diamond and still 1200 to keep it. I guess it’s the tensing points for him. I need 268 to get my 350$. 10 roses x day is 30 points. You can make it in 2 weeks. Easily. Let’s not be negative. Do Uber eats as well to help.Hold it!
