1 - 20 of 22 Posts
Go to Walmart get your oil and filter. Just unscrew drain plug and filter, screw back on and fill. A little elbow grease saves you $.
I have been doing this for 30+ years. Plus I don’t have issues with these fools stripping your drain plug threads.
I have been doing this for 30+ years. Plus I don't have issues with these fools stripping your drain plug threads.
Where do you dispose the used oil?
Even with the car wash plan discount, a full synthetic oil change is about $65.
Terribles website calls out $35 for synthetic. Yes there are fees and taxes, without out all the details you cant chose one or the other. Give a complete breakdown for the $65.
The $35 you see is the synthetic upgrade. Breakdown: $41.95 for the oil change, $35 full synthetic upgrade, $1.92, misc. shop fee, -$15.77 discount, $5.15 tax, $68.26 total.
These days depending on the car, it is most likely more to it than that. Special procedures and such.
· Banned
Plus some shops crank the drain plug and filter so tight, you need a breaker bar to get it loose.
I usually wait for a sale or rebate on oil and stock up. Filter too. Cost per DIY oil change is around $10.
I can get oil changes at Sears for $4.99, and I still do it myself, for the above reasons.
Free at O'Reillys or Autozone
Like what? Which cars?
Stick with what you know Dan, changing oil is as easy as cracking a beer. Takes me less than 10 minutes to change oil in just about any car
You gotta read the details though
You're right, I wouldn't do it but I figured it might be a place to look. Nobody touches my car. I can do anything that needs to be done, just sayin
some auto Zones let you bring in oil,but Me? i get oil changed at Valvoline,i just keep an I on them, check under car when i leave and get home, they show you the stick after they change oil,never had a issue,again, I only have done Valvoline, and once in a while Walmart, where you REALLY have to watch those guys,jmo
Just saw a sign on Ranco and Jones for a oil change (most cars) 13.95 including filter, probably not synthetic though
$14 bucks? do they use real oil, or put old oil & old in your car? asking for a friend
1 - 20 of 22 Posts
