Status
Not open for further replies.
61 - 80 of 1,299 Posts
I use frep as a auto refresher. Have a driver that sets up the frep. But the actual grabber was developed for me. It's called amazon click. It works in background and grabs when on offer page. I might release it and the cost would be around 100 bucks. Just not sure how to release and collect. It's not a hack into Amazon system . It just grabs offer rythems as they come in. If you can't make the block you have 1 minute to cancel without penalty
Not rooted phone
So you use 2 apps, frep to auto refresh and a block grabber? Is that right? If so, might have been better to pay the developer to create the auto refresh as part of the grabber. Could sell that for at least $200-400. If people will pay $400 a month to buy blocks it makes such an app valuable.
Are you worried about the income? If not, paypal or direct money transfer.
Upload app apk to google drive, collect money, send download link.
Also.....you have a 5 minute window to forfeit a block without penalty.
Carmen... yes it's two programs but I like it this way. It allows you to still refresh on your own or use auto feature....plus I will let the grabber go for cheap and if you know how to setup frep then your good to go. If you need my driver and wLk through instructions to setup frep that's a separate charge
Appreciate the offer and may take you up on it. But, be careful. If you want to drive you may want to keep things on the DL.
My guess is if amazon get's wind of you selling a program it may get you deactivated. On the other hand, you can just make it up selling the app! :)
I'm sure you're getting lot's of PM's looking to buy.
I'm currently trying to setup the emulator option as I got my hands on a hand me down laptop running windows 8. So, going to see if I can get up and running with that.
Paying for a grabber program is just silly. Nothing for the phone will work better than Repetitouch, and the methods described in this thread are significantly better than any phone based app.
If you just want a phone based bot grabber than follow the instructions I detailed in the thread "How to use bots / get blocks." Do not pay anybody for this info.
If you really need help setting up the bot for your phone, just pm me and I will help you for free. Don't pay somebody for this.
That's a generous offer and very much appreciated. I would pay right now for an "out of the box" app, meaning no root, no other software. Probably won't pay for a piece meal setup.
Don't want to repeat myself or bore people but my problem is getting every element setup on one or the other of my phones. Each time I've hit a wall with an install and it's not something easily fixed. My main phone ZTE zmax pro is unrootable and also can't get the ADB driver for it. Trust me, i've spent hours looking. Tried the google android ADB universal driver as well, no go.
Found out even super geeks can find a work around to root this phone. My other phone.....worthless at this point but will still run an old version of software so keep it around, but frep won't run properly on it.
Also, i'm not the only one....have had several private conversations with others having the same issues trying to get everything running.
I think I can get something running on this newer laptop I got my hands on.....at least I hope so! :)
Hey brother I need help with that too I can't get no blocks is there a way I can contact u .
Thanks
I did it but it shows;
What's wrong? And can you advise how to set the mitm proxy on Android 7.0?
did you ever manage a way around it.. kind of stuck on the same though i can get the server to kick on if i remove killall and connect my phone to it..but then getparms.bat does not execute
Got bluestacks running and rooted, hide my root installed and the flex app installed.
Flex app seems to load, then updates but after update it fails to run or won't sync.
When I don't update it won't sync either.
Anything special needed to make the app run in emulator?
Seems it wants to run.......just won't.
It's unbelieveable how much effort and frustration i've put into setting this crap up. Seems like the stars all have to align in order for it to work! :p
Try reinstalling BlueStacks and don't root it. There is absolutely no reason to have it rooted. Use a windows based auto clicker.
It should sync but ask you to manually enter a phone number. Just use your current cell number.
CRAP!! I thought I needed to be rooted to install repitouch.......
Balls! Ok.....I'll start over again......after a smoke! :p
So let me see if I get this strait....I can install standard bluestacks, install flex app via emulator, then can install a windows program on the PC to run an auto refresh and clicker? I'm assuming it's a windows macro recorder I need?
Reinstalled a non rooted bluestacks installed app and still same crap.
Won't sync with old version, when I update to new version is just won't load.
Anyone who wants money for a bot that you can get for free or pay less than $10 on the app store is a scammer.
Also, you can use any BOT to catch blocks but the real trick and value is in the technique. In other words, a BOT is worthless unless you know how to tap correctly and that's where the value and the money is.
Many of you who use a bot and can't catch blocks consistently or maybe catch once in a while know exactly what I'm talking about. Using a Bot does not guarantee catching blocks.
DO NOT PAY ANYONE FOR BOT AND EMULATOR...ITS A SCAM!
This post is also a SCAM and due to get shut down soon..No one has yet been able to successfully make this script work because you can't.
The op hasn't responded to anyone inquiring about how to go past some difficulties. If the op is pm'ing in private, I guarantee you he's seeking compensation.
Discussion starter · #73 · (Edited)
Not quite. I've used it to get as many blocks as I wanted for months. I helped one person offline for no compensation and it is working. It took a couple of hours to customize it. They also had a pretty good grasp on what they were doing already.
Also, this script will cream anyone using any type of tapping bot.
I put up this challenge: if anyone has a PM from me where I accept any compensation, feel free to post it here or report it.
As I mentioned, the reason I can't help is because everyone seems to have different situations than I do. Everyone is asking me about different phones, carriers, warehouses, block times, and other things. The script I wrote was for my situation only. I did it a certain way at a certain place with certain equipment. The pieces I shared are relatively common to different situations. The rest will have to be filled in.
Android packet formats are completely different than iPhone for example. That will cause problems with the script as I wrote it. So, when I said I wrote it for iPhone that is important.
I'm not able to spend the time programming for everyone beyond what I already have done for mine. What I have shared is a huge step and gets you about 80% of the way there. I've got to work like most everyone else. I've already spent a decent amount of free time sharing what I could for now.
Since I am not offering anything for compensation, that's as far as I can go for now. If you want it any sooner, try someone on a freelance site to fill in the rest for your situation. Otherwise, when I have time, I'll see what I can post as far as updates. That's what I said in my earlier posts.
I did PM him several times and offering him a compensation for the set up but he refused. So, I don't think he is a scammer.
Only posting this in public in case others are trying to do the same things. Save basmati from too many pms. :)
Setup another emulator (memu), got the app installed and can log in. But what I don't get is the slowness and lag of the emulators, bluestacks was the same, very sluggish, slow to respond. Clicking on refresh is sluggish for sure. No way I would be able to mimick the quickness of my fingers with this kind of setup. Is that normal?
The machine i'm on has windows 10, 6gb ram and quad core processor NO touchscreen. Might not be the fastest but should be very sufficient??
Want to get it right before I move on to setting up the macro recorder.
I might try another emulator, droid4x or andy and see if they run any faster, might as well go all in for this last and final attempt at autograb.
Any suggestions from anyone for emulator other than bluestack or memu?
Basmati.....do you know the bluestacks version you run and which flex app version? I've tried several on bluestacks but no go, flex app just will not
get running.
I don't actually use BlueStacks because of the lag you mentioned. I played around with it a few months ago and got it working without encountering any issues, but ultimately using a phone with Repetitouch was faster so I haven't messed with it since.
When I tested BlueStacks it was with the latest version of both the Flex app and the emulator.
I guess I'm just chasing my own tail here! :p
Oh well......looks like another dead end. Can't say I didn't try!
Honestly, and it may not seem it, but i've never not been able get technology setup and running on my own........in my lifetime I might have had to call a "tech support" line (typically internet provider) maybe 3 times! I'm my family and friends tech support person!
This is just the most ridiculous shit i've ever tried to do! Failed on 4 different devices.......no bullshit!
Appreciate you sharing what you did.
With some little testing and digging and Linux knowledge I've got it working. Think I even have it working to grab specific times. I can also say your code does work for android you just have to read the proxy output to get the device user agent to match
Carmen, have you tried NOX Player?
Thanks for the heads up on NOX....looks promising. Gave up on memu, droid4x failed to launch was just going for andy but nox looks more interesting.
Pretty damn impressive you got the vps setup and even adapted it for android. Now go put your application in at Google! :p
Learn python.....you'll be in high demand.
Get ready for an onslaught of pm's now since the majority of board members are running android. ;)
I haven't tried getting this working yet but it is very apparent that this is the only way to even have a chance of getting blocks for Miami Prime Now. Before I get started trying to figure it all out, is there a specific vps provider you would recommend?
NOX installed, app running! NICE!
Runs MUCH faster than any of the other emulators and not as much lag. That is right out of the box, sure some tweaking and can get it to run a little better.
Even has a macro recorder built in??!! Haven't dug in yet, just happy to get to this step.
I'll report back if I get it auto grabbing.
EDIT: Ok I said NICE....I meant SWWWWWWEEEEEEEEEEET!!!
Freakin' macro recorder works perfectly, can speed up the clicking etc.....
I'm going to let it run and see what happens...will report if block is grabbed.
Update: First day running the setup, got a lot of red bar "block is taken" action, much more than if I was manually refreshing but no block grabs yet. Works well, needs some tweaking, have to get the tapping sequence right.
Unfortunately we don't have a lot of action on our location. We get fast and furious spurts of drops than nothing. So, will take a few days to refine but a lot of potential.
Posting an update here rather than a new post to keep it a little more quiet.
2nd Update: After 3 days of using the auto clicker it hasn't made a difference at all. Still unable to catch blocks. So, the antibotter crowd should get a chuckle out of that.
Am able to get to the accept button but nothing but red bars and no blocks for me!
Oh well.....coming close to the end.....shouldn't take this much effort and time to get work!!??
Status
You have insufficient privileges to reply here.
