1 - 8 of 8 Posts
just like to know if anyone has use Google offline map while driving fuber and lyft. how is it
It works well, but make sure you have it set for a wide enough area. It's rare I get outside of the area I have set, because it's for most of LA/OC counties, but when I do, there is a bit of a delay when it switches over.
When you go into the offline map settings, there's something like a crop box. You expand it out to the area you want saved for offline. It will take a while to download, and needs to be updated regularly (you will get notifications) but yes, it does work.
Discussion Starter · #6 ·
thank you so i typed in los angeles ca and downloaded the map. i assume it will download streets that is near city of los angeles not LOS ANGELES COUNTY
Hard to say. Like I said, I used a custom offline map, which I used to cover most of LA/OC counties.
Android? If i remember correctly you box the area you want to download. You'll need to down load an app to block maps from accessing data too.
I use Netguard. Then got to settings>advanced >manage system applications > then block maps from accessing mobile data. Just leave it running all the time. Sometimes if i start navigation while on wifi it will connect to data when i leave wifi area. Just close out maps and start it again once away from wifi
1 - 8 of 8 Posts
