You can also unhook the battery to avoid drainage.If you're not driving nowadays and your car could be sitting for a while !
I noticed that my car brakes start to make squeaking noise since I limited my driving to once a week for grocery.
What other steps would you take ?
Yes, not making enough to afford deliveryWe still going out for grocery?!
Good tips. Thx fam 🤣Pump tires to max psi to avoid flat spots in tires
hook up battery up to maintainer or remove battery from car to prevent draining battery
Add fuel stabilizer to keep gas in good condition
wash and wax.. store under car cover for protection
Yes, I spin around when I start my second carI leave my KIA sitting "as is" for up to 5 weeks at a time. It always starts the very first time, even if left unplugged and it was -40............
FWIW starting your car does nothing to help the battery, or yoru vehicle. It is actually detrimental in cold weather. You need to drive the vehicle for at least 45-60 minutes while under load (lights and A/C or heater on as well) to charge the battery and properly heat cycle the drivetrain in cold weather.
We do, grocery delivery could take weeks!We still going out for grocery?!
Thx. I'll unplug the battery of the car I never use anymore.You can also unhook the battery to avoid drainage.
Yes, not making enough to afford delivery![]()
Or take out the tires and let the car sits on concrete blocks.Pump tires to max psi to avoid flat spots in tires
or just drive it everyday then park it when you get homeIf you're not driving nowadays and your car could be sitting for a while !
link up the tings for a quick car sesh??I go for a drive everyday at night. It's shitty being at home!
