1 - 20 of 23 Posts
If your a guy forget all that just make a trucker bomb. If you a girl or ya don't know what ya are just go to Costco and get a large supply of "depends" undergarments. Problem solved!
Any sage brush will do, stay away from the cacti...:eek:
I go to Dotty's casinos, they have cheap smokes/soft drinks.... Make a purchase, use the can. Always clean and private. And one is almost always close (except on the strip) and I won't tell my strip potty place... But it is a locals casino, and "e" and "i" appear in its name.
I drive this 1975 Datsun B-210, it has snap in floor mats.
Tire Wheel Car Vehicle Land vehicle
Remove a floor mat, there are rubber inserts in the center of each compartment for drainage.
Remove the rubber insert, slide the driver seat back, scoot forward, unzip, aim at drain and let it flow.
Works great while waiting at the airport staging lot and on the Strip at those very long red lights.
Good way to pass the time while waiting on pax that takes more than 5 minutes.
:p
There's one right next to the Planet Hollywood rideshare pick-up area. It's a small private restroom, but there's no sign on the door indicating it's a restroom.
I also use Golden Nugget restroom right when you enter the front door of the Uber and Lyft pick-up zone.
Plus, when you're around Mandalay Bay, Luxor, or Excalibar area just go across the street to Subway or MacDonalds.
one of the perks of doing this in Vegas is using the casinos for bathrooms and whatever. The most convenient one near the airport is the Tropicana.
In general, grocery stores are good. That also gives you a chance to walk around and see if anything is on sale. Found blackberries for 88 cents a package on a recent pit stop.
1 - 20 of 23 Posts
