Bands are adjustable clutches are not. If the clutch pack fails it needs replacing… this is true for both wet and dry clutches.
Bands are adjustable clutches are not. If the clutch pack fails it needs replacing… this is true for both wet and dry clutches.Same thing.
Fancy terminology.
2004 is " Modern"?
Nothing like tagging yourself in your own post… lol@W00dbutcher is not responsible for any repair advice related to up.net.
In 1974 models . . .changing transmission fluid could kill those old 3 speeds. Loss of " grit" could cause slippage .More modern than 1974… so yeah lol
Now you have to take apart 1/2 the car to change that same front seal… and it cost $5 today… lolIn 1974 models . . .changing transmission fluid could kill those old 3 speeds. Loss of " grit" could cause slippage .
Remember dropping the WHOLE damn transmission to change out a $2.00 front seal ?
76 nova-305 and 73 Pontiac Catalina. 400.
In the Catalina I had to add 1/2 quart of " reconstituted" transmission fluid to pull away from a red light sometimes !
Kept on going though.
Fun job by yourself when using only a floor jack to put car in blocks & to lower transmission when you got it loose !
You mean you've never dug a trench in the ground and push the car over it to change the transmission?In 1974 models . . .changing transmission fluid could kill those old 3 speeds. Loss of " grit" could cause slippage .
And you can repurpose that trench and bury a body when you are done…You mean you've never dug a trench in the ground and push the car over it to change the transmission?
Cars are STUPID NOW !Now you have to take apart 1/2 the car to change that same front seal… and it cost $5 today… lol
Gonna guess it had a magneto and not an alternator…Cars are STUPID NOW !
REPROGRMING SOFTWARE A 75% CHANCE OF FIXING THE LEXUS !
They put damn Computers in Tractors now !
We had a hand crank tractor when I was a kid !
Didn't need a damn battery even !
Had a crank handle you stuck into front of engine to TURN IT OVER
Damn tractor is STILL running somewhere probably.
Where the hell do you live that you're going to kill somebody the same day you're pulling a transmission out of a car?And you can repurpose that trench and bury a body when you are done…
Hell I had a ditch !You mean you've never dug a trench in the ground and push the car over it to change the transmission?
Might be the cause of the burialWhere the hell do you live that you're going to kill somebody the same day you're pulling a transmission out of a car?
$3.29 AutoZoneNow you have to take apart 1/2 the car to change that same front seal… and it cost $5 today… lol
That works. Plenty of shade underneath the car.Hell I had a ditch !
Why dig.
But . . . I worked on cars under the boat shed
Shade
What are you talking about…? They are already dead…Where the hell do you live that you're going to kill somebody the same day you're pulling a transmission out of a car?
The shed was FURTHER AWAY from the House !That works. Plenty of shade underneath the car.
I actually had a relative die from his car falling on him.That works. Plenty of shade underneath the car.
I think we have met our match fellas… lolLet me know if you need advice from a person who took high school auto shop class.
I once stayed at a Holiday Inn and we all know you can become anything spending a night in one of them places.Let me know if you need advice from a person who took high school auto shop class.
