Another idiotic decision
10079 Views 149 Replies 48 Participants Last post by  danithomme
Hello fellow drivers,
My car is a 2004 Lexus LS 430 with approximately 150k+ miles. No major repairs throughout ownership. Excluding wear and tear such as brakes, tyres and suspension, minor ones are the door actuators, oil leak (engine gasket) and cruise control. Now, I am hit with a $6000 bill for the transmission. Anyone with the ability of making logical judgement would sell the car in the blink of an eye but my heart often overrides the brain.
A few months ago, the car was sluggish occasionally going in reverse but once it was given enough time to warm up, it reversed without any problems. Fast forward to last week, instead of difficulty in reverse, the car was sluggish to accelerate. Again, the car drove fine after a few minutes. Two days ago, the car did not move upon start up unless the engine hit 2000 rpm, which is ridiculous. My experience is that the car only hits 2000 rpm or above when travelling 60 mph+.
Although as ignorant as I am, I do not need a dealer to tell me the transmission is failing. What it is beyond comprehension is that at this astronomical repair cost, the dealer would only put a re-manufactured one to my car. If the donor car has more or less the same mileage as my car, if not more, it is just a matter of time for the donor transmission to fail. Perhaps I may be better off to roll the dice, buy a used transmission from eBay and pray a transmission shop will do the job right at a fraction of the cost. The pain of losing my love is still excruciating and certainly I do not want to experience anything similar again (over the years, I have developed bonding of some kind with this car). Selling it is the last thing I hope for.
Are Toyotas made to last? I will leave this to your judgment. My answer to that would be 'depends'. Honestly with the age of this car, it is understandable that something starts to fail. As with my other newer LS, a failing suspension at 26k miles is ridiculous. This is why my jaw drops each time reading stories of Prius / Camry / Corolla that never breaks at unbelievably high miles. Why is not the case for Lexus?
Thank you for taking the time to read.
See less See more
Reactions: 2
21 - 40 of 150 Posts
Jessica, if your fluid level is in the normal range on the marks on the dip stick, again don't do anything. I will give you a link to a treatment you should try before changing the fluid or certainly before giving up on this transmission.
Not trying to be a know-it-all. Been there. Done that. I have brought transmissions back from the dead.
Holy failed troubleshooting you guys!
Jessica. Before you do anything check your fluid level. Keep the car running in park. Find the transmission dip stick. Pull it out. Wipe it off. Put it all the way in, then pull it out. What is the reading on the stick?
Low fluid levels will produce the classic symptoms she is experiencing.
Before I forget, clearly some transmission dipstick p0rn going on in your post…
  • Haha
  • Helpful
Reactions: 3
With Lucas??? LOL
All the little rubber O rings in the picture . .
Are the Reason I would NOT do a flush !
Reactions: 1
Google says that thing doesn't have a dipstick. Just a fill and a drain plug.
A full transmission should have 10 quarts of fluid but only three quarts would be drained if you just undid the plug and Let It Go. So I guess you could check it just by draining it and filling it back up again with three quarts of transmission fluid.
Reactions: 2
Yes.
I just assumed that part.
But YES !
Reactions: 1
That requires a temperature controlled fill by a shop that has the right equipment to do as such…
  • Haha
Reactions: 1
Open the fill plug.
If you can't see fluid, fill till it spills.
Dab a q tip in there. See how far down you go to see red.
So, how many more posts until the first official fight starts in this thread? Lmao
Sawdust !
Is that like putting pepper in your radiator to stop a leak?
Reactions: 2
There are LEXUS FORUMS.
DONT TRUST US.
GO TO LEXUS FORUM.
VIEW SOFTWARE FLASH.
MANY SWEAR IT WAS A FIX FOR THE PROBLEM YOU " SEEM" TO BE HAVING.
Changing fluid will allow judgement of band wear.
At 150,000 miles . . . It is time.
  • Love
Reactions: 1
All you guys are doing is hijacking the thread at this point with the off topic comments. Everyone just stop posting if you are actually interested in helping her. She often only checks the forum once in a while and will be confused from all the posts. Yes, I hijacked the thread because that is where you start.
If there is no dipstick she should take it in to an oil change place or mechanic and have them look for leaks underneath.
  • Haha
  • Wow
Reactions: 2
DONT TRUST US.
GO TO LEXUS FORUM.
Modern day transmissions do not have bands… they have clutches instead…
Reactions: 1
Worse.
It quiets down worn rear ends which come from Mexico to G.M. trucks with tolerances of 159,000 miles of wear FROM THE FACTORY.
SAWDUST & GREASE
Reactions: 1
All you guys are doing is hijacking the thread. Everyone just stop posting if you are actually interested in helping her. She often only checks the forum once in a while and will be confused from all the posts. Yes, I hijacked the thread because that is where you start.
@W00dbutcher prob had best answer… just refill the blinker fluid…
Same thing.
Fancy terminology.
2004 is " Modern"?
Same thing.
Fancy terminology.
2004 is " Modern"?
More modern than 1974… so yeah lol
Reactions: 1
Blinker fluid, muffler bearing, and flux capacitor was never mentioned.
Very disappointed in you guys.
I was Saving this . . .
" Blinker Fluid "!
Vehicle Car Hood Motor vehicle Automotive lighting
See less See more
  • Wow
Reactions: 2
@W00dbutcher is not responsible for any repair advice related to up.net.
