I got one a couple days ago, (declined as it was pool and was 5pm, so preferred to actually wait). I used DF as I almost always do to DIA. I'm assuming as long as you click the "remove destination" after ending trip, rather than logging out and back on, you'll be fine.If you use your DF does that ruin your chance to get rematched....
When you set dia as your df does it give you a warning saying you may not get trips heading that way. Or that dia is not a valid locationI got one a couple days ago, (declined as it was pool and was 5pm, so preferred to actually wait). I used DF as I almost always do to DIA. I'm assuming as long as you click the "remove destination" after ending trip, rather than logging out and back on, you'll be fine.
I had ended the ride, clicked the "remove DF" box, and got one leaving the east ramp.
Nope mine is works perfectly. From my primary locations (work, home, downtown) and accepting only the right locations and the right time of day I can usually get a DIA run 4/5 times.When you set dia as your df does it give you a warning saying you may not get trips heading that way. Or that dia is not a valid location
I would like to know the percentage of drivers who get a rematch. The queues are moving crazy slow. So I would there's a lot of rematches but I'm also hearing there's a lot that are not getting rematch. Which makes me think something else maybe going on . . . My select ride I got yesterday to Green Valley RanchWelp, had another on Select-only to the airport... set my timer for 2 minutes, waited after dropping pax off... nothing unfortunately. Select you could sit at spot #1 for a while tho (even without scammers) so that kinda sucks.
I'm typically on Select-only when I am taking people to the airport, so it seems re-match may not work for me. Oh well, it was a good thought...
I've also looked at staying these last few days - with re-match now, the queue (even on X) just crawls... I don't mind waiting an hour or so if it means I can reduce dead miles, but I'm not waiting 2+ for an extra $20...
Oy. Re-match is a blessing and a curse it seems.
deets bro!Bypassing the que now costs 1.95. Earnings are through the roof
